The Insignia NS-CLIP02 can develop a problem with power auxiliary ports malfunctioning, but don’t worry. They’re replaceable! If your device is not charging, this may be a key indicator that the port needs to be replaced.
Use this simple step-by-step guide to replace your motherboard that contains the auxiliary port in 30 minutes or less.
Locate the bottom of the device.
Peel back the adhesive sticker using a metal spudger and remove the 11mm screw beneath the sticker with a Phillips head screw driver.
Using a plastic spudger, peel off the adhesive gel stoppers.
Unscrew the six 11mm screws with a Phillips head screw driver.
Remove the bottom of the device to reveal the motherboard.
Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
Lift the motherboard from the device and lie it face down. Beware of the cables plugged in on the back side
Remove the plug to your right from the motherboard.
Remove the plug in the front of the lcd screen plug.
Remove the LCD screen plug last. For reassembly, follow the instructions in reverse order, replacing the old motherboard with the new one to fix the power auxiliary port.
