Insignia NS-BCDCAS1 Cassette Door Latch Replacement
  1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Outer Panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Outer Panels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Cassette Door Latch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by unplugging the red and black cable connected to the motherboard
  7. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the red and pink wires connecting the top of the device to the motherboard
  8. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the black shiny tape connecting the motherboard to the front of the device
    • Also disconnect the pink and white wires connecting the cassette unit to the device.
  9. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After disconnecting all the wires, the front panel is now free and easy to work on.
  10. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • To remove the cassette unit, use a 2.5mm flathead on the 4 screws holding the unit together.
  11. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While pressing the eject bottom, pull the cassette unit down and away from the front panel.
  12. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The door latch is located on the bottom corner of the cassette unit.
diego geldres
crwdns2935283:009/12/16crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-5, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 2-5, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S2G5
crwdns2942667:0crwdne2942667:0 873
