Insignia NS-B4111 Antenna Replacement
  1. Insignia NS-B4111 Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-B4111 Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-B4111 Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Antenna Replacement, External Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
    • Remove the external antenna.
  4. Insignia NS-B4111 Antenna Replacement, Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  5. Insignia NS-B4111 Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-B4111 Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  6. Insignia NS-B4111 Antenna Replacement, Antenna Base: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-B4111 Antenna Replacement, Antenna Base: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
Kristin Yoshioka
crwdns2935283:009/21/16crwdne2935283:0
984 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-5, Oliver Fall 2016 crwdns2935289:0UC Davis, Team 1-5, Oliver Fall 2016crwdne2935289:0
UCD-OLIVER-F16S1G5
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 902
