This guide will take you through the process of replacing speakers in an Insignia TV.
            Rest the TV on its top edge so you have access to the base.
            Use a Phillips #2 screwdriver to remove the four screws on the bottom of the base.
            Remove the base from the frame.
            Lay the TV face down.
            Use the Phillips #00 screwdriver to remove all of the screws from the the back of the TV.
            Stand the TV on its top edge.
            Gently pry apart the front and back of the TV.
            Remove all the pieces of tape to detach the wires from both sides.
            You want to gently peel the tape off, without pulling on the wires.
            Spread apart your TV the rest of the way, but do not disconnect any of the wires.
            Unplug the red (right speaker) cord from the motherboard.
            Unplug the white (left speaker) cord from the motherboard.
            Start by locating speaker in bottom of back panel.
            Remove screws on both sides holding the speaker in place.
            Pull the speaker out of its casing, and repeat for the process for the other speaker.
