Insignia NS-24ER310NA17 Infrared Sensor Replacement
  1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Insignia NS-24ER310NA17: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Insignia NS-24ER310NA17: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Insignia NS-24ER310NA17: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to remove the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Pry the TV open: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
  16. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Infrared Sensor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the ribbon cable from the port on the main board that corresponds with the IR sensor.
  17. Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia NS-24ER310NA17 Infrared Sensor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw holding the IR sensor and remove the sensor with the ribbon cable.
Joelle Hylton
crwdns2935283:001/22/18crwdne2935283:0
266 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G2, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S16-G2, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S16G2
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,398
