This guide will show the required steps to replace the ice tray on the Insignia Ice Maker.
Remove the 6 screws holding the rear casing on.
Remove the rear casing
Remove the 4 screws holding the Ice Tray to the body of the Ice Maker.
Remove the 4 screws holding the Ice Tray from the top.
Remove the plastic cover from the circuit board by pressing the lever on the side. A pry tool may be required.
Disconnect the water tray cord.
Where do I find insignia ice maker ns- imp26ss7 replacement ice forming tray? Can't locate item on the internet.
I found a seller on ebay that has 7 of them and is selling them for $20 shipped
what is the proper sequence to time ice tray?? it fills now on empty cycle. If I play with the micro switch on the left of the tray and get the tray to stop at the proper position ,allow it to fill, it will finish that cycle, empty, and then go back to the empty position. [the ice tray] baffled!!! can you help??
