Insignia Flex 8 NS-P16AT08 Cameras Replacement
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove connector ribbon and cameras from device casing.
Emily Guidinger
crwdns2935283:004/01/16crwdne2935283:0
527 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-1, Andersen Spring 2016 crwdns2935289:0Eastern Washington University, Team 2-1, Andersen Spring 2016crwdne2935289:0
EWU-ANDERSEN-S16S2G1
crwdns2942667:0crwdne2942667:0 280
