This guide will help you remove the back cover from the Insignia Flex 8 tablet. This is a necessary step in every replacement guide that follows this. If you need to reach the inside of your tablet, this is a good place to start.
Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
Lift the back casing away from the screen.
Set casing aside.
