The steps provided will walk you through the necessary replacement for the screen. Complete the prerequisites before performing these tasks.
Place the device on a firm surface with the device screen facing down.
Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Unplug the 2 speaker's connection from the motherboard.
Peel the yellow tape off from on top of the electrical connectors.
Flip up the black cover pieces to expose the 3 electrical connectors.
Remove 3 electrical connectors by gently pulling back on them with some tweezers.
Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
Remove the black camera connector by gently prying on it until it unhooks.
Using tweezers, remove the microphone from the the plastic cover.
Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
Remove battery by prying off with card.
Peel back the copper color electrical connector with blue opening tool.
Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
Bracket will then come off.
Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
Remove screen from case by prying with a card.
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
mine doesn’t look like that…
where can i get a new screen to buy?
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
