The motherboard replacement also replaces the charging port because they come as 1 component.
Place the device on a firm surface with the device screen facing down.
Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Unplug the 2 speaker's connection from the motherboard.
Peel the yellow tape off from on top of the electrical connectors.
Flip up the black cover pieces to expose the 3 electrical connectors.
Remove 3 electrical connectors by gently pulling back on them with some tweezers.
Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
Remove the black camera connector by gently prying on it until it unhooks.
Using tweezers, remove the microphone from the the plastic cover.
Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
This looks great. Can you provide more detail on Step 3 (opening the case?) Are there locking tabs that I need to worry about breaking? And if so, how many? Does the cover simply snap back into place?
I need to open my unit simply to disconnect the power to clear the BIOS. I stupidly disabled my USB ports and there is no way to navigate the BIOS without the (USB) keyboard (how freaking dumb is that!)
Very nicely done. Do you suppose that the SSD can be upgraded to something larger?
