If your Insignia Flex 11.6 is not holding a charge or is not starting up, use this guide in replacing the battery.
Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
Using a plastic opening tool, gently pry off the back cover.
Remove the electrical connector that connects to the battery to remove the power to the battery.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
crwdns2935229:05crwdne2935229:0
crwdns2944067:06crwdne2944067:0
Donde puedo adquirir la batería?
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Great instructions but now I cant find the battery anywhere it is 3394122-2p
