Insignia Flex 10.1 NS-P10W8100 Keyboard Connector Replacement
  1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the tape holding down the zero insertion force (ZIF) connector ribbon attached to the keyboard.
    • Use your fingernails to flip the small locking flap. Then, you can safely pull the cable out.
  5. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the yellow tape holding down the keyboard connector.
  6. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm screws using a Phillips #2 screwdriver.
  7. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector by lifting it upward.
Edgar Rodriguez
crwdns2935283:002/12/19crwdne2935283:0
1,013 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G2, Virtue Spring 2019 crwdns2935289:0Western Carolina University, Team S1-G2, Virtue Spring 2019crwdne2935289:0
WCU-VIRTUE-S19S1G2
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,056
