For instructions on how to replace the battery of your Insignia Flex 10.1 NS-P10A7100, follow this guide.
Use the blue iFixit opening tool to remove the backing of the device.
Wedge the tool in the crease between the device backing and screen.
Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
Detach the five colored wires that connect the battery to the motherboard.
Use two fingers and place one on either side of the white plastic encasing the wires.
Pull on this piece to release it from the motherboard.
Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
