Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Insignia 6-Quart Pressure Cooker Float Valve Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Savannah Webb
crwdns2935283:001/18/18crwdne2935283:0
657 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G3, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S12-G3, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S12G3
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - crwdns2934203:0crwdne2934203:0
OK after much digging, I found the old valve and now it is pressurizing.
crwdns2936753:030crwdne2936753:0 90
crwdns2942667:0crwdne2942667:0 5,406
