Insignia 6-Quart Pressure Cooker Circuit Board Replacement
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
    Where can i buy a circuit board for a Kuppet pressure cooker.Board info—GT-YLG-TY-M01
    malcolm reid - crwdns2934203:0crwdne2934203:0
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace the circuit board.
    Its good to see repair details available to buyers /users.Some manufacturers keep that info under wraps. The instructions are clear and concise.I have a Kuppet Electric Pressure board that needs changing. The info and details can be applied to many products, thereby assisting buyers who are not fortunate to have this assistance.APPRECIATED
Savannah Webb
crwdns2935283:001/18/18crwdne2935283:0
657 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G3, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S12-G3, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S12G3
crwdns2947412:08crwdne2947412:0
Where do you purchase the circuit board
Douglas Koons - crwdns2934203:0crwdne2934203:0
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - crwdns2934203:0crwdne2934203:0
Please, Where can I buy the electrical circuit?
Mohammed - crwdns2934203:0crwdne2934203:0
why is my circuit board not fixed to the top like in the diagram
david stanley - crwdns2934203:0crwdne2934203:0
where can I purchase the circuit board
de27@bellsouth.net - crwdns2934203:0crwdne2934203:0
I have an Instant Pot Duo Crisp 11-in-1 Air Fryer and Electric Pressure Cooker Combo. It doesn't power on I can e that the component on the PC board transient suppressor is burned up si I want to replace the control board. I can remove all the connections except the wide white connector with the 13 red wires on it. I've tried to pull in the connector but it won't budge. Any suggestions? The control board part number is.....MY-AIRFRY-PO2A VER: 1.0 2019-06-15
W:80mm L:112mm
I've even tried to use a pair of needle nose to pull the connector off and it won't budge it's almost like they soldered the connector to the board I'm hoping they didn't do that.
Let me know if you have any thoughts thanks Dave
Dave Barone - crwdns2934203:0crwdne2934203:0
Esta explicacion nos ayuda soluionar los problemas tecnicos que se presetan en nuevos productos .
Eladio Medina - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 3,510
