Insignia 6-Quart Pressure Cooker Circuit Board Replacement
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace the circuit board.
Savannah Webb
crwdns2935283:001/18/18crwdne2935283:0
657 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G3, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S12-G3, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S12G3
crwdns2947412:08crwdne2947412:0
Where do you purchase the circuit board
Douglas Koons - crwdns2934203:0crwdne2934203:0
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - crwdns2934203:0crwdne2934203:0
Please, Where can I buy the electrical circuit?
Mohammed - crwdns2934203:0crwdne2934203:0
why is my circuit board not fixed to the top like in the diagram
david stanley - crwdns2934203:0crwdne2934203:0
where can I purchase the circuit board
de27@bellsouth.net - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,743
