Inner Frame
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Inner Frame, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Inner Frame: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Inner Frame, Back Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Inner Frame, Back Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Inner Frame, Back Plate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Inner Frame, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Inner Frame, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Inner Frame: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Inner Frame, Inner Frame: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Inner Frame, Inner Frame: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Inner Frame, Inner Frame: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Inner Frame: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Inner Frame: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Inner Frame: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
Joe Kendall
crwdns2935283:002/15/17crwdne2935283:0
346 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-3, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 8-3, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S8G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 69
