HandsFreeLink is Honda/Acura's bluetooth audio system for holding phone conversations. The system uses a microphone in the overhead roof console assy (also home to courtesy lights, ambient light unit, and sunglass storage), and the audio system speakers. The system was included as standard equipment from 2006 - 2008 model years.
To perform this, the car may be parked or being driven. if doing this while driving please keep your focus on the job of operating the vehicle safely.
It does not matter if the audio system is turned on or not.
Insert the key in the ignition. Put the car power in ACC or ON.
Locate the HandsFreeLink (HFL) controls on the left side of the steering wheel hub.
Hold down the HandsFreeLink back button (hang-up/cancel) for 5 seconds.
The HandsFreeLink system starts a diagnostic self-test in two languages.
The diagnostic test finishes itself and exits HandsFreeLink.
Says hand free link works but phone that was hooked up doesn't connect any more
Delete the pairing in HFL (as per the manual), and pair the phone again (as per the manual).
Can't find any help with problem
why does one song randomly not play? It worked on way to work. on way home it wouldn't work. seems weird
Refer to the HandsFreeLink chapter in your TSX owner's manual for more information on using the system.
crwdns2935229:014crwdne2935229:0
crwdns2944067:034crwdne2944067:0
Can I listen to music on my Acura TSX 07 on hfl?
No, the HFL only identifies itself as a headset for phone calls. I have been able to conduct "calls" via Google Hangouts on an Android phone and iOS device (iPad), though.
My 2008 Acura TL HFL just stopped working. The icon doesn't appear on my audio screen. When I try to connect HFL says no phones have been found. It is not my phone because I haved tried to connect using my sons and sisters and it still says no phones have been found. Any help would be greatly appreciated. I called Acura they said 175 an hour to diagnose and if it can be fixed they will apply that amount towards the bill. Really? $ 175 I will by a ear bud. Help
Could be the Bluetooth module, wherever that is. Probably not a DIY job. Since a HFL function is a partial solution to combating Distracted Drive Syndrome, the $175 is a worthwhile investment. But there MAY be independent car repair shops that are well versed in Japanese brands (a friend operated one) and could offer a competitive rate. Another test: when you start the pairing process, does your phone see the car’s HFL? If not, then your car’s Bluetooth is probably compromised (i.e. the module isn’t functioning).
Ask them if the HFL is the “Telephone Assy” located in the overhead maplight bezel assembly in the ceiling. ;) Shouldn’t cost $175 to dismantle that and check out a part.
I have the same issue, on my 07 TL, Worked perfect, till I was pairing a new IPhone a couple months ago
David B.
It’s a known issue with Acura and Honda models.
http://acura-hfl-bluetooth-module-repair...
Hi, my Honda Civic 2015 touch screen power bottom do not work , display all the time the back camera steering wells bottoms not working , display “ Hondalink" and then back camera is active. NOT shows, menu screen , radio, GPS , nothing just back camera all the time, . Can help me !
That’s beyond the scope of this article. Sounds like your cars’ nav system is broken and needs repair or replacement.
I accidentally told my phone to forget the hands free link Bluetooth and now I don’t know how to undo it. Do you have any guidance?
Delete the phone from the HandsFreeLink following the voice prompts (or following the manual), then pair it again normally. I’ve had to do this a few times, works great.
I have a 2004 Acura TL and recently tried to pair my phone to the HFL. It did not work and my display just reads “PHONE" and will not change to other media.
The previous owner of my Acura TL didn’t tell me what the 4 digit code was, and now it’s locked but I want to reset it and pair my device. How can I do that?
See my answer below. You just have to put the same number in the car and the phone when pairing a new phone. If the previous owner’s phone is still paired (it was in my CPO TSX when I took delivery), you can simply delete that phone from HandsFreeLink. Check your manual for specific steps.
Problem with 2015 Honda Fit HandsFreeLink since iOS 13.3.1. Tells me to unlock my phone when a Siri set to answer when locked. Mapping will only work on blue tooth mode, not thru fm radio. Reset all settings, will give me messages when phone locked right after reset and then reverts to unlock command. Help with how to fix.
Can anybody help bought a honda civic from a garage I tried to load my phone into system it ask for my 4 digit number because it was locked does anyone no how to clear this
A more complete description would help. If you mean you were trying to pair your phone with the Civic’s HandsFreeLink Bluetooth system, then you probably encountered the common authentication step that many systems use to ensure you have access to both. Try 0000. Ensure your phone is unlocked with Bluetooth turned on. You may get an alert asking you to confirm the Bluetooth pairing, perhaps entering the same code you enter on the vehicle. ;)
2004 ACURA TL HFL seems to be working until the in use message appears, then no sound. I ran the Diagnostic test, it passed. Cleared the system and repair. Same thing?
re: 2008 acura tsx w/Navi (tech package)
How do i import speed dial numbers or just a couple of contacts onto the hfl system?
2010 accord…trying to pair a phone. When I press the hfl button there is no beep and it does not respond to voice. Not sure if it’s possible but can you reboot the hfl system.
2007 TL HFL worked just fine, until I tried to pair a new IPhone to the Bluetooth system, When I was going through the prompts,
the system locked up, on it’s own, never put a security code in, It states, the system is locked, what is the four digit passcode?
Brought it to the dealer, a few times, and they were unable to clear the code.
Purchased 3 used HFL modules, on ebay, all inoperable.
Definitely, Need it to work!
David Roselle, IL
When I try to set up my Bluetooth on my 07 Acura TL it just says hands-free booting up will it still do the diagnostics test if it's not working or if it says this
I have a 2015 Honda Civic LX- after changing the battery I lost my phone connection. I try to pair it again but the Handsfree Link doesn’t show on my phone Bluetooth selection. Can someone help on how to fix it ?
Thanks!
where is bluetooth box at ?
Does the radio code affect the Bluetooth HFL? I just got my 2008 mdx (without the navigation system) and I have not yet inputed the radio code. So, will the HFL work without the radio code or they are independent of each other?
Do you know where the HFL module is located in 2018 TLX? Will this test work on that model? Thank-you.
I couldn't connect my new Samsung phone to our Honda Fit. But on my wife's one, we could. Why not?
This procedure worked for us:
To avoid Bluetooth interference, it's preferable to bring only one phone in the car.
On your Phone (once into the Connections/Bluetooth menu activated) after setting the Bluetooth On, when you see in the Paired devices list : HandsFreeLink . That one could be an obsolete or corrupted version.
1 Then press the Setting symbol right to it (that symbol is a Gear)
2 Then, bottom right press : Delete symbol.
3 Then Scan . A «new» HandsFreeLink will appear.
4 Clic on it
Meanwhile, activate the HandsFreeLink of the car (press Top button) . It works on Accessories ( like the radio).
1 Press Top button and say: Phone settings.
2 Press top button and say: Pair.
3 Follow the instructions and enter the Paring Code when asked on your Phone. Give your new phone a name. Done.
Georges B
What if you press the HFL Button and you don't get anything happening? No Diagnostics appearing on the screen or anything at all?
And when I press the HFL Call button next to it, I don't get a beep?
What could be the cause of all that?
Faulty module? Fuse?
Yes. Check circuit breakers/fuses. See if the unit is disconnected. Ensure that the ignition is on (not ACC). Check if there is a status displayed on the MDM or touchscreen.
Also verify that the audio system speakers work (i.e. play radio, CD, AUX), since all HFL sounds are played through the audio system.
My bluetooth connects. Recognizes Iphone. if I make a call it mutes it immediately. Same with inbound. I can hear them, they cannot hear me. Is there something that is set wrong.
All the time I listen to music a voice comes on saying “starting the pairing process” it interrupts my music all the time. How do I turn it off?
How can I set up handsfreelink on 2012 honda crosstour
How can I reset handsfreelink on 2012 honda crosstour it's asking passcode
Evertime, I get in my honda 2016 cr-v and stream my music, hondalink calls my phone number..
It’s in the compartment above where the interior lights are. The darker plastic pops out with a thin screwdriver. 2 plugs to disconnect. The the outer shell of that whole thingy comes off with 4 7 mm hex screws. One plug to the module screwed to the outer frame, car interior colored piece. Takes 45 seconds to replace.
This did not work
Dana Hart - crwdns2934203:0crwdne2934203:0
Ensure you have the same vehicle/system that this is listed under.
David Spalding -
It didn't do nothing for me
Brian Sewell - crwdns2934203:0crwdne2934203:0
Ensure you don't not have the same vehicle/system that this is listed under. ;)
David Spalding -
Did absolutely nothing. Can't connect to handsfree link, nor will Bluetooth connect. Just started doing this a week ago.
Sharron Johnson - crwdns2934203:0crwdne2934203:0
You have a problem with the HFL system then. Troubleshoot or take to a dealer for investigation.
David Spalding -
omg. You saved me. My Bluetooth had no sound after the battery was disconnected (code was entered). I thought the Bluetooth had died. I tried several different phone. Forgetting/removing and re-adding with no success. Tried this process and even though the “radio” said no errors, the Bluetooth audio works again.
I thought that I would have to a thousands for a new radio.
Son Nguyen - crwdns2934203:0crwdne2934203:0
