If your Infinity v2 10.1 back case has been cracked or damaged you can replace it with a new back case. This also shows you how to open the back case even if it doesn’t need to be replaced. This is the step you must first take to fix any other problems that there might be with the Infinity v2 10.1 tablet. Overall, replacing the back case should be an easy process.
Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
Remove the speakers from the case by gently lifting them up and out of their slots.
