crwdns2956850:0crwdne2956850:0 crwdns2956756:0crwdnd2956756:0crwdne2956756:0
Infinity PC build
crwdns2869540:0crwdne2869540:0: 349
4
19
70
349
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Infinity PC build
This guide explains how to assemble an Infinity PC: mounting the chassis and Kontron motherboard into the housing, installing the CPU and heat sink, wiring the button board, LED, and cooling fans, and then adding the SSD and Wi-Fi card.
    1. Infinity PC build, Installing the skeleton in the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Installing the skeleton in the case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Installing the skeleton in the case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Screw the 3 skeleton pieces in place using 8 M3x6 Torx screws.
      • Do not forget to add a drop of threadlocker into each insert.
    2. Infinity PC build, Installing the frame into the case (continued): crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Installing the frame into the case (continued): crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Drive 2 M3x6 Phillips screws into the metal sheet inserts.
      • Do not overtighten, or the frames will break.
      • Do not apply threadlocker to these inserts, as the top sheet is screwed into these same inserts.
    3. Infinity PC build, Installing the rear blocks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Installing the rear blocks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Installing the rear blocks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Add a drop of threadlocker into the inserts.
      • Drive 2 M3x6 Torx screws into the right block.
      • Drive 3 M3x6 Torx screws into the left block.
    4. Infinity PC build, Anti-dust mesh installation: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Anti-dust mesh installation: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Anti-dust mesh installation: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply a drop of threadlocker.
      • Secure the anti-dust mesh with 2 Phillips M2x5 screws.
    5. Infinity PC build, Modifying the cooling fan cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Cut the female connector off of a cooling fan extension cable.
      • Remove the label from the extension.
    6. Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the outer sleeve back about 3 cm.
      • Cut about 2 cm off the outer sleeve.
      • When putting the sleeve back in place, you should get this.
    7. Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Strip the wires.
      • Twist the exposed part.
      • Tin the wires.
    8. Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Modifying the cooling fan cable (continued): crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Cut the original connector so that 2-3 cm of wire remains.
      • Strip, twist, and tin the wires.
      • Slide heat shrink tubing over the outer casing.
      • As well as over each individual wire.
    9. Infinity PC build, Cooling fan cable modification (continued): crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Cooling fan cable modification (continued): crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Solder the wires.
      • Wires of the same color must be soldered together (yellow with yellow, black with black, etc.).
      • Heat the small heat-shrink tubing with the heat gun.
      • Then [apply heat to] the large one; it must cover the small ones as much as possible.
    10. Infinity PC build, CPU and heat sink installation: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, CPU and heat sink installation: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, CPU and heat sink installation: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the motherboard on a stable, anti-static surface. Use foam or an anti-static mat to prevent electrical damage.
      • Remove the film from the heat sink fastener.
      • Stick the fasteners under the motherboard.
      • Gently lift the retention lever to open the socket.
    11. Infinity PC build, CPU and Heatsink Installation (continued): crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, CPU and Heatsink Installation (continued): crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently place the CPU into the socket. It should seat without force. If you feel resistance, check the alignment and try again.
      • Handle the CPU with care, avoiding touching the connector pins or the gold contacts.
      • Once the CPU is in place, lower the retention lever to secure the CPU in the socket.
      • The CPU cover should pop off on its own; otherwise, remove it carefully.
    12. Infinity PC build, CPU and heat sink installation (continued): crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, CPU and heat sink installation (continued): crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Apply a thin layer of thermal paste to the top of the CPU, if you have not already done so.
      • Place the heat sink on the CPU and secure it by tightening the screws.
      • It is recommended to tighten the heat sink screws in a cross pattern (see photo) to ensure even pressure.
    13. Infinity PC build, Kontron board installation on the grid: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Kontron board installation on the grid: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Install the backplate.
      • Install the motherboard.
    14. Infinity PC build, Installing the Kontron card on the grid (continued): crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Installing the Kontron card on the grid (continued): crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Apply a drop of threadlocker to each screw.
      • Install 4 M3x6 Torx screws.
    15. Infinity PC build, Cooling fan installation: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Cooling fan installation: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Cooling fan installation: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Drive two 2 mm Phillips screws.
      • Connect the cooling fan.
    16. Infinity PC build, Adding the button and the LED: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and the LED: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and the LED: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Connect a cooling fan extension to the socket (see photo).
      • Estimate the required cable length.
    17. Infinity PC build, Adding the button and LED (continued): crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Cut the black cable so that 25 cm remains.
      • Slide the outer sheath back to cut it by 7 cm without cutting the wires.
    18. Infinity PC build, Adding the button and LED (continued): crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Cut the yellow and black wires so there is about 2 cm of wire outside the sheath.
      • Strip, twist, and tin the yellow and black wires.
    19. Infinity PC build, Adding the button and the LED (continued): crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and the LED (continued): crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and the LED (continued): crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Solder 2 75-ohm resistance in series to the short leg of the LED as shown in the photo.
      • Be careful, the LED is very sensitive to heat, so avoid keeping the soldering iron on the small leg for too long.
      • Before proceeding to the next step, please test the LED. To do this, use the multimeter in continuity test mode with the positive probe on the long leg and the negative probe on the short leg. If the LED lights up, it is working.
      • Slide a piece of heat shrink tubing onto the yellow wire.
      • Solder the LED, with the negative terminal on the yellow wire and the positive terminal on the black wire.
      • Heat the heat shrink tubing.
      • Be careful, the LED is VERY sensitive to heat, so it is recommended to heat the 5 mm section near the LED with the soldering iron.
      • Add and heat a second piece of heat shrink tubing that covers both wires/legs of the LED.
    20. Infinity PC build, Adding the button and LED (continued): crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Strip, twist, and tin the green and blue wires.
      • Glue the LED in place with the hot glue gun.
      • Verify that the LED is clearly visible.
      • Gluing the LED while the motherboard is plugged in and/or turned on makes the task a bit easier.
    21. Infinity PC build, Adding the button and LED (continued): crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Install the button if you haven't already. With the seal on the inside.
      • Screw on the nut and tighten it with a flathead screwdriver.
      • Slide a piece of heat shrink tubing onto each wire (green and blue).
    22. Infinity PC build, Adding the button and LED (continued): crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the button and LED (continued): crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Tin the terminals of the button.
      • Solder the wires (no polarity).
      • Heat the heat shrink tubing with the heat gun.
    23. Infinity PC build, Kontron Air Scoop Installation: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Kontron Air Scoop Installation: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Kontron Air Scoop Installation: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Add a drop of threadlocker into the top holes.
      • No threadlocker in the bottom holes.
      • Drive 2 M2x5 Phillips screws from the outside.
      • Drive 2 M3x6 Torx screws from the inside (bottom holes).
    24. Infinity PC build, Adding the front USB extension: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the front USB extension: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the front USB extension: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a USB extension.
      • Deburr the holes of the extension well with a Phillips screwdriver, before inserting it into its slot.
      • Be careful to have the "bars" of the extension facing upwards (see photo).
      • Secure the connector with 2 Phillips screws.
    25. Infinity PC build, Front USB Extension Connection: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Front USB Extension Connection: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Front USB Extension Connection: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Connect the elbow connector.
      • Stick 2 large cable clips as shown in the photo.
      • Route the cable through the cable clips.
      • Plug the extension into the elbow connector.
    26. Infinity PC build, Connecting the cooling fan cables: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Connecting the cooling fan cables: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Connecting the cooling fan cables: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Connect the various cooling fans (see schematics).
      • Hook the various cables into the cable clips.
    27. Infinity PC build, Wi-Fi Card Installation: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Wi-Fi Card Installation: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Install the Wi-Fi card.
      • Use the original screw to secure the Wi-Fi card.
    28. Infinity PC build, Adding the antennas and Wi-Fi card: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the antennas and Wi-Fi card: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the antennas and Wi-Fi card: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the adhesive film from the antennas.
      • Stick the antennas down, placing them as far apart as possible.
      • Route the wires through the cable guides.
      • Connect the antennas.
      • Be careful, they are fragile.
    29. Infinity PC build, Adding the SSD: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the SSD: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infinity PC build, Adding the SSD: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the SSD screw.
      • Install the SSD.
      • Drive the original screw into the SSD adapter.
    30. Infinity PC build, Top metal plate installation: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infinity PC build, Top metal plate installation: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Add the top metal plate.
      • Secure the 4 black M3x6 Phillips screws (do not do this if parts are missing).
    31. Infinity PC build, It's finished!!: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On to the next one, or… a coffee.
crwdns2935291:0crwdne2935291:0
Modixia
crwdns2935283:007/01/24crwdne2935283:0
1,954 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 70
crwdns2959996:0crwdne2959996:0 349
