Unzip the following zipper at the very top of the chair. It is hidden beneath Velcro .
You will need to disconnect the power cables on Left and Ride side of the hood assembly . They are attached via a clip. Simply push the clip down and pull them apart.
You need to find the 6 way air valve on the left and right hand side.
You then need to Locate and remove the top air hose from the valve. You can usually identify this hose by the armor cover it has on it . Additionally its the only air hose that goes to the top.
To remove the hood piece lift upwards to slide it off of the Frame points.
Marked here are the 4 frame points . Remember where these are for re- assembly.
