Infant Optics DXR-8 Speaker Replacement
  1. Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, remove screen protector from front of monitor.
    There's a layer of adhesive between the screen protector and the white plastic behind it.
    Jared Astillero - crwdns2934203:0crwdne2934203:0
    The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
    Marco Smolla - crwdns2934203:0crwdne2934203:0
  2. Infant Optics DXR-8 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
    Lauren Skinner - crwdns2934203:0crwdne2934203:0
  4. Infant Optics DXR-8 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
    Be more specific about how to remove the speaker. Explain how to soften the adhesive, etc. Make sure you point out which tools to use when removing the speaker. How do you grasp it?
    Patty Remmell - crwdns2934203:0crwdne2934203:0
  5. Infant Optics DXR-8 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker from casing using metal spudger.
    • Place new 8W speaker in the casing and connect wire.
    Where do I get a replacement speaker?
    Ryan Dahlberg - crwdns2934203:0crwdne2934203:0
Larsha Johnson
crwdns2935283:008/26/15crwdne2935283:0
538 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-4, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 6-4, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S6G4
crwdns2947412:05crwdne2947412:0
Where to purchase the replacement speaker?
Keiundra Joiner - crwdns2934203:0crwdne2934203:0
Where can we purchase the replacement 8w speaker part
lea placek - crwdns2934203:0crwdne2934203:0
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - crwdns2934203:0crwdne2934203:0
Thanks for this. Found something on Ali Express, just need to figure out the right size
https://www.aliexpress.us/item/325680361...
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 17,636
