Infant Optics DXR-8 Monitor Screen Replacement
  1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, remove screen protector from front of monitor.
    There's a layer of adhesive between the screen protector and the white plastic behind it.
    Jared Astillero - crwdns2934203:0crwdne2934203:0
    The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
    Marco Smolla - crwdns2934203:0crwdne2934203:0
  2. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
    Lauren Skinner - crwdns2934203:0crwdne2934203:0
  4. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
    What do you do when you reassemble everything and the screen only shows white and nothing else? You can still hear the sound, but no image.
    Louise - crwdns2934203:0crwdne2934203:0
Daniel Edward Camp
crwdns2935283:002/18/21crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G1, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G1, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S3G1
Hey Daniel!
Thanks for sharing ??
Where did you get the replacement part?
Ro Brandi - crwdns2934203:0crwdne2934203:0
On Amazon is the quickest option.
Hilitand LQ035NC111 LCD Display, 3.5inch TFT RGB LCD Display Module 320 x 240 Display Panel LQ035NC111 54pin LCD
Stebe -
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
James Quinlan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 5,174
