Infant Optics DXR-8 Monitor Screen Replacement
  1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Monitor Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
Daniel Edward Camp
crwdns2935283:002/18/21crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G1, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G1, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S3G1
Hey Daniel!
Thanks for sharing ??
Where did you get the replacement part?
Ro Brandi - crwdns2934203:0crwdne2934203:0
On Amazon is the quickest option.
Hilitand LQ035NC111 LCD Display, 3.5inch TFT RGB LCD Display Module 320 x 240 Display Panel LQ035NC111 54pin LCD
Stebe -
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
James Quinlan - crwdns2934203:0crwdne2934203:0
Does this improve the brightness of the screen or is it essentially an OEM replacement? I have found the monitor to be basically unusable in daylight conditions (like every midday nap) so I’m hoping to add some anti glare and boost the screen brightness/contrast.
Thanks for the information!
Owen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 5,771
