Infant Optics DXR-8 Charging Port Replacement
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, remove screen protector from front of monitor.
    There's a layer of adhesive between the screen protector and the white plastic behind it.
    Jared Astillero - crwdns2934203:0crwdne2934203:0
    The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
    Marco Smolla - crwdns2934203:0crwdne2934203:0
  2. Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
    Lauren Skinner - crwdns2934203:0crwdne2934203:0
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old charging port and solder the new one in place.
  7. Infant Optics DXR-8 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the unit over to ensure a correct fitment.
    Where do you buy a new charging port? Also, you didn't include new charging port as an item that is needed for this tutorial. Might be self-explanatory but why say "no parts required" when clearly a part is required?
    In any event, thanks for this tutorial. Much appreciated!
    Paul Lee - crwdns2934203:0crwdne2934203:0
    The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
    Donovan Zusalim -
Donovan Zusalim
crwdns2935283:001/24/17crwdne2935283:0
300 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-4, Banghart Winter 2017 crwdns2935289:0Cal Poly, Team 13-4, Banghart Winter 2017crwdne2935289:0
CPSU-BANGHART-W17S13G4
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - crwdns2934203:0crwdne2934203:0
Donovan Zusalim -
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
Danny Conrad - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,662
