India Mark III Foot Valve Replacement
  1. India Mark III Foot Valve Replacement, Access Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement, Access Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark III Foot Valve Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark III Foot Valve Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark III Foot Valve Replacement, Chain: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Chain: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Chain: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark III Foot Valve Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark III Foot Valve Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark III Foot Valve Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark III Foot Valve Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nut from the chain bolt.
  9. India Mark III Foot Valve Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the washer from the chain bolt.
  10. India Mark III Foot Valve Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the chain bolt.
  11. India Mark III Foot Valve Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark III Foot Valve Replacement, Head: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Head: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Head: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark III Foot Valve Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two bolts and nuts from the handle side.
  14. India Mark III Foot Valve Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark III Foot Valve Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
  16. India Mark III Foot Valve Replacement, Chain: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement, Chain: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
  17. India Mark III Foot Valve Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the head flange up about one foot above the tank.
  18. India Mark III Foot Valve Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
  19. India Mark III Foot Valve Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
  20. India Mark III Foot Valve Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lower the head flange.
  21. India Mark III Foot Valve Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
  22. India Mark III Foot Valve Replacement, Pump Rod: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Pump Rod: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement, Pump Rod: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the spacer from around the pump rod.
  23. India Mark III Foot Valve Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the jam nut from the top of the pump rod.
  24. India Mark III Foot Valve Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the head flange.
  25. India Mark III Foot Valve Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw the jam nut back onto the top of the pump rod.
  26. India Mark III Foot Valve Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw a T-handle onto the top of the pump rod. Tighten the T-handle against the jam nut.
  27. India Mark III Foot Valve Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Have one team member lightly pull up on the T-handle, while another loosens the rod clamp. This will prevent damage to the pump.
  28. India Mark III Foot Valve Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rod clamp from the tank.
  29. India Mark III Foot Valve Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the T-handle to rotate the entire pump rod clockwise several full turns.
    • The foot valve is threaded and will screw into the base of the traveling valve, allowing you to pull the two valves up out of the well together.
    • Keep turning until the resistance greatly increases. The foot valve will provide this resistance when fully screwed into the traveling valve base.
  30. India Mark III Foot Valve Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T-handle to pull the pump rod straight up out of the well.
  31. India Mark III Foot Valve Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the pump rod up a few feet, past the first joint.
  32. India Mark III Foot Valve Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the rod clamp on the base of the pump.
  33. India Mark III Foot Valve Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure there is at least 6 inches of space between the joint and the rod clamp to allow yourself enough room to work. If necessary, continue pulling the rod out of the well before tightening the rod clamp to ensure sufficient spacing.
  34. India Mark III Foot Valve Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure the rod clamp is tightened against the pump rod.
  35. India Mark III Foot Valve Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two wrenches to loosen the joint between the top section of pump rod and the rest of the pump rod.
  36. India Mark III Foot Valve Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the top section of pump rod from the joint.
    • Lift up the top section of pump rod and remove it.
    • Set the section of pump rod in a sanitary place, and remove the T-handle from the top.
  37. India Mark III Foot Valve Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw the jam nut and T-handle onto the top of the remaining section of pump rod still in the well.
    • Tighten the T-handle against the jam nut.
  38. India Mark III Foot Valve Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the rod clamp and repeat the procedure for the next section of pump rod.
  39. India Mark III Foot Valve Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When you reach the final section of the pump rod, remove the rod clamp from the tank.
  40. India Mark III Foot Valve Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the pump rod and valves straight up out of the well.
    • Set the rod aside, taking care to keep the valves clean and off the ground.
  41. India Mark III Foot Valve Replacement, Foot Valve: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark III Foot Valve Replacement, Foot Valve: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the foot valve from the traveling valve.
  42. India Mark III Foot Valve Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark III Foot Valve Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the foot valve from the traveling valve.
    • Check the foot valve components for signs of wear or damage.
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
509,961 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,464crwdne2935297:0
crwdns2942667:0crwdne2942667:0 494
