India Mark II Riser Main (Tripod) Replacement
  1. India Mark II Riser Main (Tripod) Replacement, Access Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Access Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark II Riser Main (Tripod) Replacement, Chain: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Chain: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Chain: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nut from the chain bolt.
  9. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the washer from the chain bolt.
  10. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the chain bolt.
  11. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark II Riser Main (Tripod) Replacement, Head: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Head: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Head: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two bolts and nuts from the handle side.
  14. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
  16. India Mark II Riser Main (Tripod) Replacement, Chain: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Chain: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
  17. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the head flange up about one foot above the tank.
  18. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
  19. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
  20. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lower the head flange.
  21. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
  22. India Mark II Riser Main (Tripod) Replacement, Head Flange: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Head Flange: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Head Flange: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the chain support from around the pump rod.
  23. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the jam nut from the top of the pump rod.
  24. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the head flange.
  25. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw the jam nut back onto the top of the pump rod.
  26. India Mark II Riser Main (Tripod) Replacement, Tank: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Tank: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Tank: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw a T-handle onto the top of the pump rod. Tighten the T-handle up against the jam nut.
  27. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the rod vise.
  28. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rod vise from the tank.
  29. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four bolts connecting the tank to the top flange.
    • Use one wrench on the bolt and a second wrench on the nut beneath. Hold the bolt still and loosen the nut.
  30. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the tank 45 degrees in order to get a better grasp on it.
  31. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the tank straight up, about one foot.
    • The tank is attached to the riser main, and the two must be lifted as a unit. Be careful and get help, as this can be very heavy.
  32. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Have a third person place the pipe vise around the riser main, on top of the top flange.
    • Tighten the pipe vise securely around the riser main.
  33. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure the pipe vise to the top flange with two bolts and nuts to hold the pipe vise in place.
  34. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the tank from the riser main.
  35. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the tank up a few inches above the top of the riser main.
  36. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the rod vise between the riser main and the tank, around the pump rod.
    • Tighten the rod vise onto the pump rod.
  37. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the T-handle from the pump rod and remove it.
    • Keep the T-handle ready to reattach to the pump rod after the tank is removed.
  38. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tank.
  39. India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a coupling over the pump rod, on top of the rod vise.
  40. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the T-handle to the top of the pump rod.
  41. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen and remove the rod vise from the pump rod.
    • The coupling will drop down onto the riser main.
  42. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the coupling onto the end of the riser main.
    • Use a pipe wrench to tighten the coupling onto the riser main.
  43. India Mark II Riser Main (Tripod) Replacement, Riser Main: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Riser Main: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement, Riser Main: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the tripod pipe vise to the top of the riser main.
    • Close the tripod pipe vise around the riser main, and lock it shut.
  44. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten the tripod pipe vise.
  45. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This procedure requires an important communication dialog between the rope operator and the pipe vise operator.
    • The rope operator's job is to pull hard on the rope to take up the slack, and announce that they've "got it," to let the vise operator know that they're holding the weight of the riser main.
    • The vise operator will then announce "loosening," and loosen the pipe vise.
  46. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the pipe vise loosened, pull the riser main up out of the well.
    • Pull only as high as the tripod vise operator can comfortably reach.
  47. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The pipe vise operator then announces "tightening," and tightens the pipe vise.
    • It is now safe to loosen and remove the tripod pipe vise.
    • Be sure to loosen and then fully remove the tripod pipe vise from the riser main. Sliding it down the riser main will scratch the pipe, creating dangerous sharp grooves and causing rust.
  48. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lower the tripod pipe vise down to the bottom of the exposed section of riser main pipe.
  49. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure the tripod pipe vise to the riser main pipe and tighten it securely.
  50. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the lifting procedure: loosen the pipe vise and pull on the rope to raise the riser main another few feet.
  51. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tripod has an indentation built into its top to guide the riser pipe.
    • As you're raising the riser pipe, guide it into the indentation.
  52. India Mark II Riser Main (Tripod) Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 India Mark II Riser Main (Tripod) Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the riser pipe until the first coupling clears the pipe vise.
    • You will need to open the pipe vise wider to accommodate the coupling.
    • Once the coupling is through the pipe vise, tighten the pipe vise.
    • Be sure to raise the riser main pipe high enough that you can attach the tripod pipe vise to the section of pipe beneath the coupling.
    • From here we have pictures for loosening a coupling with the tripod?
Andrew Optimus Goldheart
crwdns2935283:010/17/09crwdne2935283:0
512.150 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023.562crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 713
