InFocus X2 Lamp Replacement
  1. InFocus X2 Lamp Replacement, Open the Lamp Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Open the Lamp Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Open the Lamp Door: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. InFocus X2 Lamp Replacement, Disconnect the Lamp: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Disconnect the Lamp: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Disconnect the Lamp: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. InFocus X2 Lamp Replacement, Remove the Old Lamp: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. InFocus X2 Lamp Replacement, Insert the New Lamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the replacement lamp into the projector.
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
crwdns2935103:0crwdne2935103:0
Paulina Duarte
crwdns2935283:009/19/13crwdne2935283:0
553 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 crwdns2935289:0UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013crwdne2935289:0
UMASSD-GULBRANDSEN-F13S1G3
crwdns2942667:0crwdne2942667:0 932
