InFocus Screenplay 4805 Motherboard Replacement
    1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    2. InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
    3. InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
    4. InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
    5. InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
    1. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
      • Remove the white tab connected to the light bulb.
    2. InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
      • Pinch the two black tabs on the inside of the cover to remove.
      • Gently pull on the long white tab to remove it.
Marilyn Urness
crwdns2935283:009/28/17crwdne2935283:0
671 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G3, Crane Fall 2017 crwdns2935289:0Eastern Washington University, Team S2-G3, Crane Fall 2017crwdne2935289:0
EWU-CRANE-F17S2G3
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 739
