InFocus Screenplay 4805 Lamp Replacement
  1. InFocus Screenplay 4805 Lamp Replacement, Remove the lamp door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front panel assembly removal is not required.
    • To remove the lamp door, use a metal or plastic pry tool and unclip the lamp door from the projector. Set this aside for reassembly.
  2. InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Beyond this step, the lamp can be replaced as an assembly and the guide is complete. If you want to rebuild the lamp with a new bulb and reuse the old housing, refer to this guide: InFocus Screenplay 4805 Lamp Rebuild
    • If you are replacing the lamp as an assembly, follow this guide in reverse from this step.
    • Remove the two gold 1 cm screws and washers on the side of lens housing using the 4.0 flat-head bit
    • Pinch the white wire tab to gently detach the side that connects with the lens housing.
  3. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
  4. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
  5. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
To reassemble the device, follow these instructions in reverse order.
Marilyn Urness
crwdns2935283:009/28/17crwdne2935283:0
671 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G3, Crane Fall 2017 crwdns2935289:0Eastern Washington University, Team S2-G3, Crane Fall 2017crwdne2935289:0
EWU-CRANE-F17S2G3
To remove and later disassemble the lamp, you don’t need to remove whole cover. Just open the lamp bay door and follow the steps starting  from 6!
madyogi - crwdns2934203:0crwdne2934203:0
madyogi, exactly. You are absolutely right!
ilya.zhizhin - crwdns2934203:0crwdne2934203:0
I was able to fix an old projector I got for $40. Thank you so much for the tutorial.
Madelyn Tapia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,698
