InFocus LP540 Projector Main Board Replacement
  1. InFocus LP540 Projector Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus LP540 Projector Main Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
Jorge L Navarro
crwdns2935283:001/22/14crwdne2935283:0
533 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-17, Regan Winter 2014 crwdns2935289:0Cal Poly, Team 13-17, Regan Winter 2014crwdne2935289:0
CPSU-REGAN-W14S13G17
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,248
