InFocus IN3104 Speaker Replacement
  1. InFocus IN3104 Speaker Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus IN3104 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the speaker wire that is located right behind the cooling fan.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws on the frame brackets.
  6. InFocus IN3104 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the side panel.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws.
    • Remove the speaker by pulling it straight out.
Tae Min Kim
crwdns2935283:001/24/20crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S5-G5, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S5-G5, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S5G5
crwdns2942667:0crwdne2942667:0 275
