InFocus IN3104 Lamp Replacement
    1. InFocus IN3104 Lamp Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
    2. InFocus IN3104 Lamp Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    1. InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
    2. InFocus IN3104 Lamp Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
    1. InFocus IN3104 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the four 6 mm screws.
      • You may need to use a flexible extender to help remove the screws easily.
    2. InFocus IN3104 Lamp Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 InFocus IN3104 Lamp Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the lamp power cable situated beside the lamp by pulling it straight out.
      • Remove the lamp by pulling it straight out from the device.
Tae Min Kim
crwdns2935283:001/24/20crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S5-G5, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S5-G5, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S5G5
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,099
