In-Ear Headphone Control and Mic Block Disassembly
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
Your headphones should now be working!
crwdns2935229:05crwdne2935229:0
Alexander
crwdns2935283:009/10/18crwdne2935283:0
296 crwdns2915208:0crwdne2915208:0
Thanks a lot this worked perfectly thank you very much
MD Ratul - crwdns2934203:0crwdne2934203:0
Very good lesson. Thanks a lot...
PK Chatterjee - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 16,241
