IdeaPad Yoga 13 Keyboard Replacement
  1. IdeaPad Yoga 13 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your laptop before beginning disassembly.
    • Open the laptop to locate the keyboard.
  2. IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool in the seam between the keyboard and laptop body.
    • Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
  3. IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
    • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
    • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
    My keyboard was also stuck down with double sided tape near the sides 1cm down from the top edge. These didn't want to let go easily, be careful pulling them away.
    Frank Puranik - crwdns2934203:0crwdne2934203:0
    Also, on my keyboard there are metal latches under the keyboard. To remove the keyboard it needs to be slid towards the screen a few mm before you can lift it. When reassembling do the reverse, engaging the latches, or the keyboard will not stay down properly.
  4. IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IdeaPad Yoga 13 Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ribbon cable connecting the keyboard to the motherboard.
    • Use the tip of the opening tool to lift the black flap on the connector.
    • With the twezers, gently lift the ribbon cable out of the connector.
    • Be careful when reinserting the ribbon cable.
    • Ensure the cutouts on the end of the cable match the tabs on the connector.
    The cable is not lifted . It should be pulled parallel to the line of the memory chips. The Lenovo service guide makes this clear.
    Getting the cable back i was tricky. in the end I almost had the keyboard vertical to east the bend on the connector as I pushed it back in gently - then it finally went in. When you push the retaining flap back down the white line on the ribbon cable should just be showing - then you have it in properly.
    also you may think you’ve not got the cable in enough but actually when you flip the tab down if you can see about a.1.5mm of cable above the white line you should be good. just turn on the computer to check keyboard works before screwing back together
    Tollon Adkins - crwdns2934203:0crwdne2934203:0
    where can i buy original battery for my lenovo yoga 13 ideapad in gurgaon?
    Premlata - crwdns2934203:0crwdne2934203:0
Remington Jones
crwdns2935283:001/17/17crwdne2935283:0
756 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Spring 2017 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Spring 2017crwdne2935289:0
WCU-VIRTUE-S17S1G1
Best tutorial for Lenovo Yoga 13 keyboard replacement !
Saved my Yoga 13 . Thanks a lot.
djibe - crwdns2934203:0crwdne2934203:0
Unfortunately my ribbon cable connector lock snapped and I'm having trouble ensuring all connector ports are established. Tried using electrical tape but doesn't seem to work. Be grateful for any advice
robbarry89 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,841
