The battery is a crucial component of the computer, providing power to run the device. Fortunately, cosmetic damage is rare as the battery is protected, however the battery can lose is lifespan over time. The battery may need to be removed to replace the battery or to allow easier access to other components.
Open the laptop to locate the keyboard.
Insert a plastic opening tool in the seam between the keyboard and laptop body.
Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
Locate and remove the screws holding the bezel to the laptop body:
Two 3 mm Phillips screws
Three 5.5 mm Phillips screws
Flip the laptop over.
Locate and remove the screws holding the bezel to the bottom panel:
Ten 4.5 mm Phillips screws
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Flip the laptop back over.
Locate the small trackpad ribbon cable and use the opening tool to lift the black flap on the connector.
With tweezers, gently pull the ribbon cable out of the connector.
Locate the power board cable and disconnect it by pulling the cable head towards the front of the laptop.
Lift the keyboard bezel off the laptop. The bezel is secured to the chassis by 10 plastic clips around the circumference that can be released with the plastic pry tool.
Remove the screws holding the battery to the chassis:
Four 4 mm Philips screws
Gently lift the battery out of the laptop.
crwdns2935229:012crwdne2935229:0
Does the battery sold by ifixit work with the Yoga IdeaPad 13 20175?
Jason Scott - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
