Follow these steps to remove the back plate from your Ibanez 5 String Bass Model SR405QM guitar. This is useful if you need to access the output jack, the potentiometer, or the tremolo system. A Phillips #2 screwdriver is required to remove the screws on the backplate.
Use a Phillips #2 screwdriver to remove the four screws on the backplate.
Remove the cap by lifting upwards, revealing the circuitry of the instrument.
Thank you so much for the guidance!
