IT-8800 -8500 Footrest Disassembly
  1. IT-8800 -8500 Footrest Disassembly, Footrest: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 8 screws marked in red .
    • NOTE: THERE IS 2 PIECES THAT ACT AS ONE COVER. DO NOT SLIDE OR PRY THESE PIECES APART FROM EACH OTHER IT WILL RESULT IN DAMAGE.
    • Remove 3 screws marked in Orange
  2. IT-8800 -8500 Footrest Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 bolts and lock washers.
  3. IT-8800 -8500 Footrest Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From here the lower piece will be free from the frame .
    • Air hose will then be disconnected from the nozzle marked with an arrow. Then unplug the three wires from the relay PCB.
    • Mounted here will be a screw threaded through 2 plastic holders . remove the screw and don't lose the plastic holders.
  4. IT-8800 -8500 Footrest Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unzip the the zipper marked with a red line. This will completely disconnect the upper assembly from the lower assembly.
    • Note in this photo the frame has been completely removed . NO need to do that for this repair.
  5. IT-8800 -8500 Footrest Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws and 2 washers for each foot pad.
    • EACH OF THESE FOOT PADS HAVE 2 WASHERS ON ONE END , THIS SERVES A PURPOSE . DON'T FORGET THIS DURING REASSEMBLY
  6. IT-8800 -8500 Footrest Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unzip the the leather from the bottom
    • The zippers sometimes don't have a zipper handle, please use a large paper clip.
    • Once leather is unzipped this is what you should see . Go ahead and remove the entire leather cover .
  7. IT-8800 -8500 Footrest Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 screws on the top cover .
    • This foam is glued to the plastic . Do your best not to rip it , use a sharp blade to avoid any tearing.
    • Pro Tip: No need to peel this entire piece off . Just peel the edges and leave center glued .
  8. IT-8800 -8500 Footrest Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 screws.
    • This cover will not come off until the top cover is removed first. Additionnally follow the same rule , keep the middle glued and peel back the edges
  9. IT-8800 -8500 Footrest Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 bolts .
    • RECOMMENDED: USE A MAGNETIC TIP SCREW DRIVER FOR THIS STEP. OTHERWISE THOSE BOLTS CAN AND WILL FALL INTO THE HOLLOW FRAME PIECE
  10. IT-8800 -8500 Footrest Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 bolts in each corner .
    • RECOMMENDED: USE A MAGNETIC TIP SCREW DRIVER FOR THIS STEP. OTHER WISE THOSE BOLTS CAN AND WILL FALL INTO THE HOLLOW FRAME PIECE
  11. IT-8800 -8500 Footrest Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IT-8800 -8500 Footrest Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • unplug motor wire.
    • Unscrew grounding wire. Be sure to reuse this screw and washer if new assembly did not include one.
  12. IT-8800 -8500 Footrest Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • YOU ARE DONE
PLEASE REMEMBER THE FOLLOWING DURING REASSEMBLY:
- When gluing the foam to the plastic DON'T over do it , just spray for a second on the desired area and press foam onto glue.
- When Gluing the foam be sure your edges are smooth and everything is secured , other wise you will get bumps in the leather .
- There will be wrinkles on the leather when its re stretched , this is normal . They usually dissipate over time.
- If the Bolts from step 2 will not go on use a utility knife and cut X shaped holes on the leather until you can physically see the thread .
- When attaching the 3 wires and 1 hose from step 3 BE SURE these are not getting pinched between the upper and lower portion. Otherwise you will get no air to the feet area.
Good Luck .
Nick
crwdns2935283:005/30/17crwdne2935283:0
2,764 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 67
