ILVE Microwave Replacement Bulb Replacement
  1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brown plug.
    • The screw attaching the microwave is below
  2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cross point screws from the outer case back
    • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
    • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
  3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The socket is on top right side of the microwave
    • Remove the plugs
    • Bend up the metal clips, and pull out the socket
  4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
    • The glue goes all the way down the thread so remove as much as you can see.
    • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
  5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you re assemble the outer case make sure the tabs on the front go either side of the front.
Martin Hampton
crwdns2935283:002/13/16crwdne2935283:0
1.308 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 3,558
