ILVE Microwave Replacement Bulb Replacement
    1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the brown plug.
      • The screw attaching the microwave is below
    2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the cross point screws from the outer case back
      • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
      • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
    3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The socket is on top right side of the microwave
      • Remove the plugs
      • Bend up the metal clips, and pull out the socket
    4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
      • The glue goes all the way down the thread so remove as much as you can see.
      • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
    5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • When you re assemble the outer case make sure the tabs on the front go either side of the front.
Martin Hampton
crwdns2935283:002/13/16crwdne2935283:0
1,350 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 4,499
