IBM Thinkpad T60 RAM Replacement
  1. IBM Thinkpad T60 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM Thinkpad T60 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 RAM Replacement, Palm Rest: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM Thinkpad T60 RAM Replacement, Palm Rest: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    The screws we need to remove all supposedly share the same pictogram imprinted on the bottom case. If this is true why have you circled the rightmost screw in the photo above? The forth pictogram is near the screw below and to the left of the circled screw?
    airshack - crwdns2934203:0crwdne2934203:0
  4. IBM Thinkpad T60 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM Thinkpad T60 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
    • Detach the connector by pulling upwards on the white tab.
    Putting it back on should be covered too, as it’s really hard to get everything lined up. Would be nice for some tips on that. Took me and other experienced guy 45 minutes to get the thing back on, and have all the screws seat!
    Glenn - crwdns2934203:0crwdne2934203:0
    Where in this guide does it say how much RAM is supported? Am I missing something? Looks like two slots?
  6. IBM Thinkpad T60 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM Thinkpad T60 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press out the two tabs on either side of the card at the same time.
    • The memory card will slide upwards at a 20 degree angle.
  7. IBM Thinkpad T60 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the memory card from the slot by pulling perpendicular to the slot.
    The relevant screws are all marked with the same three pictograms alongside. These can be interpreted as indicating that they need to be removed to give access to touchpad, keyboard and memory.
    With care, it is possible to remove or insert memory without releasing the touchpad cable.
    Mike Kearney - crwdns2934203:0crwdne2934203:0
    Assuming Mike Kearney’s pictogram tip is correct we have a problem with this tutorial. Specifically, there’s a problem with the red circles identifying the four screws to remove in Step three. The right-most screw circled in this tutorial does not share this pictogram? The screw below and slightly to the left of the one circled has the pictogram. Which screw on the right side of the computer shall we remove?
    airshack -
crwdns2935229:014crwdne2935229:0
Cody Kratochvil
crwdns2935283:001/11/13crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-9, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-9, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G9
crwdns2917034:0crwdne2917034:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 14,767
