IBM ThinkPad T43 WiFi Card Replacement
  1. IBM ThinkPad T43 WiFi Card Replacement, Removing Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement, Removing Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the laptop top-down onto the workstation.
    • Remove all screws circled in red.
    • When removing screws, group them by size. The bottom case of the laptop includes a sticker that shows the size of the screws.
    • When reassembling the device, note the numbers by the screw holes and use them to know what size screw correlates to what hole.
  2. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop so that the IBM ThinkPad logo is facing up.
    • Slide the unlocking switch to open the device, and lift the display (not the palmrest assembly).
    • Make sure to unlock the laptop before opening, as the palmrest assembly is not screwed in to the bottom case.
  3. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the laptop open, hold the bottom edges of the top case and slowly lift.
    • Be sure to not lift the palmrest completely, since there is a ribbon cable still attached to the bottom case.
  4. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon cable by lifting on the plastic backing square.
    • Do not lift by the ribbon cable itself, as this can cause it to tear.
  5. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Wi-Fi Card is located towards the middle bottom of the laptop
  6. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two wires connected at the top of the Wi-Fi card.
    • Hold the card down and use the tweezers to pinch the plug and pull up.
  7. IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T43 WiFi Card Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place fingers on the two clips holding the card in place
    • Pull the clips outwards until the the card pops up
    • Pull the card out by pulling out away from your body
    • To replace, follow these steps in reverse order
    • Make sure that the side with the short end is on the left when you put it back in.
aLiX pIeRRe
crwdns2935283:003/19/18crwdne2935283:0
855 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 crwdns2935289:0UMass Dartmouth, Team S6-G4, Bernier Spring 2018crwdne2935289:0
UMASSD-BERNIER-S18S6G4
I need to know what's role of the cables AUX and MAIN because i cut one
M a n i _001 - crwdns2934203:0crwdne2934203:0
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
crwdns2942667:0crwdne2942667:0 11,336
