IBM ThinkPad T42 RAM Replacement
    1. IBM ThinkPad T42 RAM Replacement, Battery Clips: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
      • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
    2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully grab the battery, then pull it straight out, not at an angle.
    1. IBM ThinkPad T42 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the pictured screwed holding the memory cover in place.
    2. IBM ThinkPad T42 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the cover open carefully (flathead screwdriver might help)
      • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
      • Pull the stick out carefully.
      • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
Kevin Rehm
crwdns2935283:004/19/10crwdne2935283:0
472 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 29-76, Johann Spring 2010 crwdns2935289:0Cal Poly, Team 29-76, Johann Spring 2010crwdne2935289:0
CPSU-JOHANN-S10S29G76
crwdns2935297:0180crwdne2935297:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 7,693
