IBM ThinkPad T30 Processor Replacement
  1. IBM ThinkPad T30 Processor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Processor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Processor Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Processor Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Processor Replacement, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
    • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
    • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
  3. IBM ThinkPad T30 Processor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Processor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Processor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
    • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
    • Use the plastic opening tool to gently pry the connector up from the motherboard.
    • You can now safely remove the keyboard.
  4. IBM ThinkPad T30 Processor Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Processor Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm Phillips #0 screws securing the fan assembly.
  5. IBM ThinkPad T30 Processor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Processor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently pry the heat sink assembly upwards.
    • Be sure to reapply thermal compound on the processor and the heat sink when reassembling the device.
    • Be aware that there still is a wire attached to the fan that is connected to the motherboard upon removal.
  6. IBM ThinkPad T30 Processor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Processor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
    • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
    • Warning—the stuff is hard to clean off clothing.
    • Follow iFixit's guide for [crwdns2936915:0crwdne2936915:0] for a detailed explanation.
  7. IBM ThinkPad T30 Processor Replacement, Processor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To start off, make sure to power off and disconnect the laptop from any power sources.
    • Afterwards, flip the laptop and slide the battery out from the device.
    • Remove the keyboard by unscrewing all the screws and carefully lift it.
    • Also, disconnect the ribbon cable that was attached to the motherboard.
  8. IBM ThinkPad T30 Processor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, find the heatsink and the fan assembly. Unscrew the heatsink and lift it off gently.
    • Do it in a diagonal patter to avoid uneven pressure.
    • Processor pins and corners are pointy--be careful!
    • Beware of the pins, don't bend them!
    • As you remove the CPU locking mechanism, make sure to use a flathead screw to take out the screws.
    • Needs to be rotated counterclockwise.
    • Lift the processor and handle it by the edges, so you avoid static damage.
    • Finally, install the new processor.
    • Make sure there is a triangle that matches with the marker on the CPU socket.
    • Install all the components back into the laptop and insert the screws tightly.
    • Double check if the laptop works by rebooting it.
    • Ensure that it doesn't overheat and the performance of the laptop is good to go.
Alex Kost
crwdns2935283:010/05/12crwdne2935283:0
271 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-20, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 3-20, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S3G20
crwdns2942667:0crwdne2942667:0 5,289
