IBM ThinkPad T30 Hard Drive Replacement
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad T30 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
crwdns2935229:011crwdne2935229:0
Allie Knauer
crwdns2935283:010/05/12crwdne2935283:0
90 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-20, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 3-20, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S3G20
good description and photos..thanks :]
David - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 19,609
