Remove the 6mm screw
Pull out the hard drive
Peel the sticker and remove the 15mm screw
Remove all 6 of the 16mm screws
use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
Lift the keyboard and remove the keyboard ribbon cable from the laptop
Remove the one 21mm screw
Take the tool and run it under the black case.
Unscrew the 2 (17mm) screws
Unscrew the 6mm screw
Gently disconnect the white display ribbon cable
Unscrew 4 (6mm) screws
Lift screen straight up
Flip the ThinkPad over so that it is upside down.
Push latch switch to the left.
Gently lift the battery out and away from the ThinkPad
LIft the bracket out
Remove one 6mm screw
Remove 3 18mm screws
Take off the bracket on the CPU fan
Lift the CPU fan
Pull out the cable attached to the motherboard
Turn the locking screw to unlock with the flat head screwdriver
LIft the CPU out
