IBM ThinkPad A31 CPU Replacement
    1. IBM ThinkPad A31 CPU Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 6mm screw
      • Pull out the hard drive
      • The hard drive might be a little tough to pull out
    1. IBM ThinkPad A31 CPU Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Keyboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The sticker is to keep the warranty on the laptop so once removed the warranty is void
      • Peel the sticker and remove the 15mm screw
      • Remove all 6 of the 16mm screws
    2. IBM ThinkPad A31 CPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
      • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
    3. IBM ThinkPad A31 CPU Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the keyboard and remove the keyboard ribbon cable from the laptop
    1. IBM ThinkPad A31 CPU Replacement, Display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Display: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the one 21mm screw
    2. IBM ThinkPad A31 CPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Take the tool and run it under the black case.
    3. IBM ThinkPad A31 CPU Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the 2 (17mm) screws
      • Unscrew the 6mm screw
    4. IBM ThinkPad A31 CPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently disconnect the white display ribbon cable
      • Pulling on the ribbon cable too hard could result in worse or faulty connection.
    5. IBM ThinkPad A31 CPU Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew 4 (6mm) screws
      • Lift screen straight up
      • If not lifted straight up the screen could get damaged
    1. IBM ThinkPad A31 CPU Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, Battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the ThinkPad over so that it is upside down.
      • Push latch switch to the left.
      • Gently lift the battery out and away from the ThinkPad
      • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
    1. IBM ThinkPad A31 CPU Replacement, CPU: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, CPU: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement, CPU: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • LIft the bracket out
    2. IBM ThinkPad A31 CPU Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove one 6mm screw
      • Remove 3 18mm screws
      • Take off the bracket on the CPU fan
    3. IBM ThinkPad A31 CPU Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the CPU fan
      • Pull out the cable attached to the motherboard
    4. IBM ThinkPad A31 CPU Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A31 CPU Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the locking screw to unlock with the flat head screwdriver
      • LIft the CPU out
Thomas Stone
crwdns2935283:003/19/18crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 crwdns2935289:0UMass Dartmouth, Team S2-G2, Bernier Spring 2018crwdne2935289:0
UMASSD-BERNIER-S18S2G2
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,587
