IBM ThinkPad 600E Hard Drive Disk Replacement
  1. IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Hard Drive Disk Replacement, Hard Drive Disk: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a coin, remove the coin screw by turning counterclockwise.
    • It's best to use a thicker coin, such as a nickel.
  6. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic spudger, pry off the plastic cover by pulling it out.
  7. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Utilizing your fingers, untuck the tab and pull to remove the hard drive.
  8. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
    • four 3mm PH0 screws
    • The metal bracket is still attached with a weak adhesive tape, gently pry it off with a spudger.
  9. IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad 600E Hard Drive Disk Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
Kevin Nguyen
crwdns2935283:010/04/16crwdne2935283:0
737 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 1-4, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S1G4
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 3,693
