How to remove the keyboard for repair or replacement on the IBM ThinkPad 560z.
Remove the 7 mm Phillips #0 screws.
Remove the 10 mm Phillips #0 screws.
Remove the 14 mm Phillips #0 screw.
Insert the plastic opening tools between the right and left sides of the latch.
Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
Insert the plastic opening tools towards the right side of the latch.
Gently pry the right side out to release the top cover.
Use your fingers or a spudger to detach the connector.
Carefully lift and remove the keyboard.
Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
