Hyundai Sonata Battery Replacement
  1. Hyundai Sonata Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyundai Sonata Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the Hood Latch in the car door.
    • Pop the hood.
  2. Hyundai Sonata Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the hood and secure the arm.
    • Not securing the lift arm could result in injury!
  3. Hyundai Sonata Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the car battery and use the ratchet to loosen the negative (-) cable.
  4. Hyundai Sonata Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, use the ratchet to loosen and remove (+) the positive cable.
  5. Hyundai Sonata Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hyundai Sonata Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the bolt that secures the battery in place.
    • You can use either a 12 mm wrench, or in the example we used a ratchet extension with a 12mm socket
  6. Hyundai Sonata Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the car battery.
  7. Hyundai Sonata Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the new car battery.
    • Do not place the new battery on the ground. Place it on a piece of cardboard or plywood, but not dirt or asphalt.
Kace Coble
crwdns2935283:010/24/17crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
University of Mount Olive, Team S1-G1, Pennell Fall 2017 crwdns2935289:0University of Mount Olive, Team S1-G1, Pennell Fall 2017crwdne2935289:0
UMO-PENNELL-F17S1G1
If the bolt that secures the battery is rusted to the nut on the underside of the battery tray, the bolt will spin freely without loosening. This has the potential to be time consuming, because it is difficult to access the nut on the underside of the battery tray.
Justin Viener - crwdns2934203:0crwdne2934203:0
there is a ductwork over the batery in my car that goes to the air clener assembly, so how do you remove this part before the bolts for the battery?
Bruno85 - crwdns2934203:0crwdne2934203:0
I found out that the ductwork for the fresh air is held on by three plastic screws that come off then pop out the plastic retainers and lift the air duct out of the way and reverse to install
Bruno85 -
How do you reset the radio after changing your battery
Gandypgh - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 149
crwdns2942667:0crwdne2942667:0 46,091
